RCU Forums - View Single Post - Real Flight Basic
Old 02-28-2012 | 08:41 AM
billd76's Avatar
billd76
Default RE: Real Flight Basic
ORIGINAL: gphil
Still trying to get a real controled landing in. Beginning to think the trim may be a factor. The flight controls seem well but the throttle trim may too low. Right now there is no such thing as a power off, dead stick , approach. If you throttle back to ''o'' uncontrollable crash happens. going to add a little higher idle and see what happens. Question, what does the switch on top left of controller do? I think it is control response maybe. The one on the right side operates flaps and gear. But as of right now, no way to line up on final high or low. Just will not happen. Gonna give it a week then who knows. This unit will allow me to see a second plane in flight and the controller. I do much better watching the little plane. Oh well . gphil
That sounds like you do not have the plane properly trimmed out. Get the plane high, fly level at half throttle. the plane should fly level and straight without any input with the elevator, rudder or ailerons, while at half throttle. Adjust trim as requried to acheive level straight half throttle, hands off flight. Once you do that, then landing and all the other flying should be easier,
