RCU Forums - View Single Post - When do you use a retract servo?
Old 03-01-2012 | 08:39 AM
Pete Bergstrom
Default RE: When do you use a retract servo?
"Retract" servos are designed for mechanical retracts, have 180 degrees of throw, and actually shut themselves off at either end of the servo movement so there is not a constant drain on the battery.
If you are using a pneumatic retract system most all mini servos will provide the torque needed to operate the valve.
Pete</p>
