 When do you use a retract servo? >
Old 03-01-2012 | 08:31 AM
Default When do you use a retract servo?
I am currently building a Top Flight T-34 and have a question regarding the retracts. I am planning on having sequencing doors. I see the "retract" servos for sale and I want to know when do you use them and what is their advantages? It seems to me that they have a lot of torque, but how much torque do you need to activate a valve? Are they for mechanical retracts or something?
Brian
Old 03-01-2012 | 08:39 AM
Default RE: When do you use a retract servo?
"Retract" servos are designed for mechanical retracts, have 180 degrees of throw, and actually shut themselves off at either end of the servo movement so there is not a constant drain on the battery.
If you are using a pneumatic retract system most all mini servos will provide the torque needed to operate the valve.
Pete</p>
