RCU Forums - View Single Post - U-Can-Do 60 build, intalling a DLE20
Old 03-01-2012 | 12:35 PM
  #44
elvir
Default RE: U-Can-Do 60 build, intalling a DLE20
I started to work on the plane today after cooling down a few days . I know i should have reinforced the landing gear , but I did not know how bad it was. until I started to put it back tougher today , the triangle stock was not even close to being square there was a gap about 2 mm on one side so no support at all . and the ply with the two hole where the wing dowels go into did not have much glue at all to hold it to the side fuselage where you could see where glue was missing from the inside. so the side walls spread apart and then the hard wood with the landing gear just came out. so for everyone else glue the landing gear block from the inside.
ID:	1734061   Click image for larger version
ID:	1734062   Click image for larger version
ID:	1734063   Click image for larger version
