ORIGINAL: mcovalsk
ORIGINAL: Panther F
Wouldn't just a longer flash unit be better? Like for the KT or the M51 Sherman?
Not knowing what you're using it for.
~ Jeff
Well I'm electronic engeener and to solder a new cable is easy and cheap than to buy a new flash unit, Tamiya's shipped aren't cheap.
Being an "electronic engineer", you should be able to afford a $40.00 flash unit ... huh?
I'd make sure it has a good mechanical connection as well as being soldered. Don't want to add too much resistance to that lead.
~ Jeff
