Tamiya flash unit...extended
ORIGINAL: Green Amphibian
You need to use the same size wire and splice it into the existing harness before the plug. Solder and heat shrink the joints.
Herman
Herman
Wouldn't just a longer flash unit be better? Like for the KT or the M51 Sherman?
Not knowing what you're using it for.
~ Jeff
~ Jeff
ORIGINAL: Panther F
~ Jeff
~ Jeff
ORIGINAL: mcovalsk
Well I'm electronic engeener and to solder a new cable is easy and cheap than to buy a new flash unit, Tamiya's shipped aren't cheap.
ORIGINAL: Panther F
~ Jeff
~ Jeff
Being an "electronic engineer", you should be able to afford a $40.00 flash unit ... huh?
I'd make sure it has a good mechanical connection as well as being soldered. Don't want to add too much resistance to that lead.
~ Jeff
Being an "electronic engineer", you should not have asked this kind of question...
But thanks for the others who maybe wondered if it was possible (easy) or not...
ORIGINAL: Elefant
Being an ''electronic engineer'', you should not have asked this kind of question...
Didn't want to go there but ...~ Jeff
Resistant soldering might be needed in this case.
~ Jeff
~ Jeff
I am planning on doing the same thing. Thanks for the info,Paul, did you just use the same gauge cable/wire for both the MG and the main gun flash unit?
