It's not the same motor in both hulls. It's just the same kv, nothing about those motors are the same. That's like saying all v-8s are the same regardless of brand. I acutally like the AQ 1800 motor slightly more then the PB 1800, The AQ seems to have a tad more torque. Both are good choices, if you are newbie however the mono maybe be the better choice as they are easier to setup and drive then a cat is. You will be happy with either one, both companies are awesome and both have excellent warrenties. I like the throttle response of the Aquacraft esc's also, the PB esc's low end throttle sensitivity is not that good. JMHO
ORIGINAL: keenan
Thanks guys, the Impulse 31 and the motley crue both look like good choices and they have the same motor and batteries but which one is faster stock and which one can be upgraded easier.
