RCU Forums - View Single Post - smoker pump
Thread: smoker pump
Old 04-24-2002 | 11:49 AM
  #41
Chris Huhn
Default smoker pump
Originally posted by woketman
Yo, you guys that are using Powermax cans for smoke tanks: what mods are you doing to the can tops to use for this? Are you installing Festos or simply sodering brass tubes in (a dicey proposition with some residual fuel inside)? What is the capacity of one can and how long can you run the smoke? Thanks.
Mark,
I first cut one apart to see how it was put together, but basically, I punctured the valve with a drill. I then aeropoxied a brass nipple in place. Same thing for the overflow.
If I remember correctly, it works out to 23oz of smoke fuel. This runs for probably 2 minutes. The last 30 seconds or so are kind of spotty becasue the "clunk" is not heavy enough. The clunk is actually an aluminum pipe that is probably about 6 inches long. Im thinking about putting a real clunk on there and glueing the top of the can back together.
The only festo I have is a one way between the overflow and the engine.
Chris
