RE: DLE-30 idle and vibration problems
Hello,
I have a dle 30 with side carb tillotson.
After the 1 1/2 gallon brake in, I put it on my brand new Yak 55.
I noticed problem on the low idle I cannot go lower than 2000 rpm the high rpm is 6950 with 19x8 jfx.
The problem is that the engine cannot hold lower that 1800 without stop and even in 2000 sometimes had the same problem.
Some guys in the field propose to change to rear carb.
Any suggestions?
