RCU Forums - View Single Post - really nice hull upgrade kits
Old 03-05-2012 | 12:07 AM
BlackCat_2
Default RE: really nice hull upgrade kits
<span lang="en" id="result_box"><span class="hps">I read the</span> <span class="hps">memoirs</span> <span class="hps">of German</span> <span class="hps">anti-aircraft gunners</span> <span class="hps">in '41</span><span>.</span>
<span class="hps">Two</span> <span class="hps">Soviet</span> <span class="hps">T-34s</span> <span class="hps">jumped out</span> <span class="hps">of their</span> <span class="hps">position.</span> <span class="hps">T-34</span> <span class="hps">escaped</span> <span class="hps">from the encirclement.</span>
<span class="hps">T-34</span> <span class="hps">destroyed by</span> <span class="hps">tracks</span> <span class="hps">the position of</span> <span class="hps">the two</span> <span class="hps">anti-tank</span> <span class="hps">guns.</span>
<span class="hps">German</span> <span class="hps">anti-aircraft gunners</span> <span class="hps">gave</span> <span class="hps">all</span> <span class="hps">shots</span> <span class="hps">on the tank</span> </span><span lang="en" class="short_text" id="result_box"><span class="hps">From</span> <span class="hps">a distance of about</span> <span class="hps">30 -</span> <span class="hps">40 meters </span></span><span lang="en" id="result_box"><span class="hps">with no hope of</span> <span class="hps">life .</span> <span class="hps">The first</span> <span class="hps">T-34</span> <span class="hps">stopped and</span> <span class="hps">the crew</span> <span class="hps">jumped out of the</span> <span class="hps">tank.</span> <span class="hps">Then the</span> <span class="hps">anti-aircraft gunners</span> <span class="hps">opened fire</span> <span class="hps">in bursts and</span> <span class="hps">the second</span> <span class="hps">T-34. </span></span><span lang="en" id="result_box"><span class="hps">The second</span> <span class="hps">T-34</span> <span class="hps">stopped</span> <span class="hps">the same way.</span> <span class="hps">The crew</span> <span class="hps">jumped out of the</span> <span class="hps">tank.</span> <span class="hps">The Germans</span> <span class="hps">captured the</span> <span class="hps">stunned</span> <span class="hps">crew</span> <span class="hps">T-34 tanks</span><span>.</span> <span class="hps">The tanks themselves</span> <span class="hps">were</span> <span class="hps">not damaged.</span>
</span><span lang="en" id="result_box"><span class="hps">The German</span> <span class="hps">added</span> <span class="hps">- that the</span> <span class="hps">anti-aircraft gunners</span> <span class="hps">thus</span> <span class="hps">captured</span> <span class="hps">several</span> <span class="hps">Soviet</span> <span class="hps">tanks in</span> <span class="hps">'41</span><span>.</span>
<span class="hps">After the defeat of</span> <span class="hps">the Germans near Moscow</span> <span class="hps">- more than</span> <span class="hps">they</span> <span class="hps">do not</span> <span class="hps">fall to</span> <span class="hps">such happiness</span><span>.</span></span>
<span class="hps">I think</span> <span class="hps">-</span> <span class="hps">affected</span> <span class="hps">by several factors</span> <span class="hps">-</span>
<span class="hps">1</span><span>.</span> <span class="hps">Poor</span> <span class="hps">visual</span> <span class="hps">equipment</span> <span class="hps">T-34</span> <span class="hps">first</span> <span class="hps">editions</span>
<span class="hps">2</span><span>.</span> <span class="hps">Tired</span> <span class="hps">crews</span> <span class="hps">that</span> </span><span lang="en" id="result_box"><span class="hps">escaped</span> <span class="hps">from the encirclement</span></span><span lang="en" id="result_box"> <span class="hps">for several days</span>
<span class="hps">3</span><span>.</span> <span class="hps">The lack</span> <span class="hps">of ammunition of soviet tanks
</span></span>
