RCU Forums - View Single Post - Sealing hinge gaps
Old 03-07-2012 | 07:37 PM
Bill Clark's Avatar
Bill Clark
Default RE: Sealing hinge gaps
ORIGINAL: 8178
If you build the control surfaces with zero gap you do not need to mess with trying to seal them with MonoKote. See page 2 and 6 of this link: http://www.rcuniverse.com/forum/Howa...2434444/tm.htm
I'm on your side. If your hinge job is precise you dont need to seal it. a .010" gap will not let enough air volume through to cause flutter in my opinion. On 3D planes I seal them because getting +-50deg and no gap is tough. If you end up with a decent gap and sloppy linkages then yes its probably required
