ORIGINAL: Bill Clark
I'm on your side. If your hinge job is precise you dont need to seal it. a .010'' gap will not let enough air volume through to cause flutter in my opinion. On 3D planes I seal them because getting +-50deg and no gap is tough. If you end up with a decent gap and sloppy linkages then yes its probably required
It's not a question of flutter on a thoroughbred precision aerobatic model. Rather, a matter of model lock and grooving to a control setting. An .010" gap is too much gap on this type of model. Pattern is not about banging sticks all over the TX.
