That is a nice classic hog!........ I know what you mean by 'complete'
When you are sitting at my stage it just sorta looks built. I have a list a mile long. Plan to set my controls up the same way. Did you put a meter on the wings? Curious how yours built out in that regard. That and how it weighs in (pretty sure mine is going to be a pretty fat) Yours outta be near unlimited vertical with that much motor in a good OS two stroke.
Still have to run the glow sys wiring and a million other things. Got my radio system today and the motor is on it's way from Horizon repair from getting the case replaced from the tree strike. Should be as good as new. Nearly is, less than a gal of fuel through it before the crash. Sprayed the Minwax Polycrylic on the covering this morning. Two coats and it came out ok. Good enough for me anyway. Been kinda dreading that step. Wasen't quite sure what i was getting into.
Maybe the winds will lay for you soon Daddyo, and good luck on the maiden. Get us a video if you can!
