ORIGINAL: sskianpour
They reduce range. Simple test: Plug it in, and perform a range check. Measure your distance. Then unplug it and do a range check. Measure your distance. Almost double the range when it is NOT plugged in. Hazard. Don't do it Jeff!
Shaz
Really, even with 2.4? Is that with Spektrum or Futaba? I'm wondering if its noise somehow being coupled into the satellite RX connections?
Bob
