RE: Plettenberg maintenance?
Good to know that you have taken the ring off.
To mount it, you may need to consider the same mount method with good high-temperature locking liquid. The ring probably should be put in the freezer prior the mount.
The 350 degree heat should destroy the integrity of the glue and maybe you could lightly sand it clean with 400grit sand paper?
