carb
Not a problem...You can turn the whole carb or just take the shaft out and put it in from the otherside..If you turn the carb you will have to put a pressure tap into the crankcase and another one in the back plate of the carb...Connect the two and you're all set.On some engines it's easy to put the pressure tap into the cylinder where the transfer port goes up the side..What engine do you have ?
