RE: Prolog
Thanks, Rudy.
Thanks, Robert. A followup question - Is the red wire you're pulling and cutting the one that would connect to the black wire of the other pack to put the two packs in series? That is a good idea it will leave several inches of un-necesssary wire on the ground. I'm guessing the different lengths of wire and locations of balance connnectors can be accomodated in the plane setup and the charging set up as well.
Your external connection do you prefer the more vertical orientation of the wires as compared to a more horizontal arrangement? You probably could count the number of times I have even touched wires of that function on one hand. I know I have disconnected them for a few people when calling for them but have never connected them hot. I would guess that the orientation could make a difference in how easy it is to work with. Comments?
Thanks, Tom
