RCU Forums - View Single Post - Eliminate ignition battery?
Old 03-17-2012 | 07:11 PM
av8tor1977's Avatar
av8tor1977
Default RE: Eliminate ignition battery?
You could just leave the flywheel on it, and use a a regular screw on prop hub. Then if it runs ok on Gas/Glow, which I am sure it will, then you can have a prop hub made that eliminates the flywheel, or use the flywheel center and a screw on prop hub as I mentioned....
AV8TOR
