RCU Forums - View Single Post - Phoenix Extra 330S 60-90 Size
Old 03-20-2012 | 12:01 AM
  #1889
ameyam
Default RE: Pheonix Extra 330S 60-90 Size
What make CF gear were you using?
I reinforced the original LG Block with tristock. Its difficult to have a single piece of tristock go through the two small holes in the rear bulkhead. Also, the block is not exactly 90 Deg to the bulkhead, dont ask me why. So I cut pieces just long enough to go through the holes, applied a thick paste of 30 min epoxy and filler and then placed it inside. I also tacked it in place with CA so it wouldnt move while the epoxy dried. Further, I fibreglassed over the block from outside. That reinforced it quite a bit. When I had a deadstick last week and landed downwind, it was the fastest landing I have ever had. I had only a few meters before the end of the field after the wheels touched so I ruddered hard left. This is a 4.2kg airplane (9lb), it completely flattened the stock aluminium gear. But the LG Block remained intact
Dont know whether you can do something similar though
Ameyam
