RCU Forums - View Single Post - Engine Vibration ..... please help
Old 03-23-2012 | 09:02 AM
hogflyer's Avatar
hogflyer
Default RE: Engine Vibration ..... please help
Sounds like your mixture is too rich.
Start with setting your high-end mixture first - lean it until the RPM peaks, then back it off about 4 clicks rich, or about a 400 RPM drop.
Next start leaning out the idle mixture about 1/16 of a turn at a time and see what it does. You'll find that when you make a change to one mixture setting it will affect the other, and on some engines it just takes a bit of tinkering with them before you have everything dialed in.
Hogflyer
