ORIGINAL: earlwb
Although I have a couple of old Tatone stands, which are all aluminum and quite rugged and long lasting, I switched over to a nice test stand made by a guy who sells them on Ebay from time to time.
I have run engines as small as a .049 on it and as large as a 1.80 engine too.
For some engines the right side bolt and nut can interfere with the muffler and on small engines, I sometimes had to make a puck to hold the engine so that the needle valve or carb throttle would clear the mounting clamps.
He happens to have on up on Ebay at this time too.
http://www.ebay.com/itm/ENGINE-TEST-...item3373a5f819
Sorry, for some odd reason the forum software changes the URL to the pictures a \ASP is changed to \A when I save the message. So those links don't work here.
Norvel .059
ASP .28
Irvine .61
GMS 1.20
ASP 1.80
Any Idea where you can get the aluminum channel that is used on the test stand. I have looked almost everywhere.
