CG
Mine is at 5 7/8 inches at the wing root, measured using the GP balancer. It is just a bit nose heavy but it flies great.
Most folks are balancing somewhere between the front of the wing tube and the center of the tube.
Mine was very tail heavy and I found that using a high torque pull-pull rudder servo under the canopy saved a lot of weight in the nose.
