RCU Forums - View Single Post - increasing compression on Saito 4S..!?
Old 03-25-2012 | 12:57 AM
  #61
Kostas1's Avatar
Kostas1
Default RE: increasing compression on Saito 4S..!?
ORIGINAL: canardlover
Hello again, another update on the Saito CR increase and some more ''swiss cheesing''.. Recently bought a Saito .72 GK in good shape and as usual I could not resist to take it apart for a closer inspection. Everything was in good order except that it was equipped with the early plastic rear crankcase cover which is rather flimsy. So I bought a new reinforced cover and gave my usual ''swiss cheese'' treatment and milling of the crankcase to take off 0.8mm for an increase in CR.
This time I went a bit further in my lightening of the conrod. I drilled four holes each 4.2mm dia. which is more than ever before..[X(]....!! See pic of the setup and wish me luck, testing it very soon...Thank you..!
As far as the conrod holes are concerned,
don't you think that you threw away some of the stifness and rigidity;
