RCU Forums - View Single Post - SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
Old 03-25-2012 | 03:15 PM
  #652
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
The so called regulator in a Perry pump is just a maximum pressure regulator. It is not a demand regulator like with a Cline or Iron Bay.
You can use the crank case pressure of a two stroke engine to make pressure if you use a check valve in the line.
