RCU Forums - View Single Post - Juggernaut 2
Thread: Juggernaut 2
Old 03-28-2012 | 05:07 AM
The Mad Modder's Avatar
The Mad Modder
Default RE: Juggernaut 2
ORIGINAL: nickelson87r
So I put the Novak super roost esc from the rs4 on the jugg, took the reciever off my villian ex boat and woolaa it works! I need new tires though, the stock ones are completly rotten out and have holes, what would work? or where could i get oem replacements?
Also how many cells can that Novak super roost handle? and could I wire the motors in parallel for higher speed?
I just checked and can't find anywhere that sells stock tires for the Juggernaut. Tires for the clod buster, super clod buster(same thing as the original, but different colored bumpers), and txt-1 will fit, though. Currently all of those are discontinued, so tires for them are being sold at scalpers prices on ebay.
There are two viable options for tires.
1.The Super Clod will be re-released this year, so stock tires for the clod will become more available and at lower prices.
2. RC4wd has some reasonably priced clod tires.
http://store.rc4wd.com/Clod-Tires_c_87.html
The super rooster will handle 6-10 cells nicad or nimh. How many turns are the motors in it?
Instruction manual
http://www.teamnovak.com/download/in...ter_superr.pdf
Please keep in mind that the Juggernaut 2 is easy to roll if you aren't careful with it, especially at higher speeds. As heavy as it is, a couple of rolls will destroy the stock hard plastic body. That said, I recommend a lexan body for bashing.
