RE: Setup Blade mQX to Spektrum DX6i Transmitter
I selected a new model and named it in ACRO mode with all the servos set to normal(none reversed) and sub trims set to zero andturned thenturned theTx off.
I then Installed the battery in the mQX, turned on the Tx simultaneously with the bind button and waited 5 to 10 seconds until the Rx went from flashing to solid blue and that was it.
No further inputis required whatsoever.
