Setup Blade mQX to Spektrum DX6i Transmitter
I am looking for a setup procedure to setup my Blade mQX Quadcopter to my Spektrum DX6i Transmitter?
Anyone who can help?
I fly Mode 1 and the Tx given with the RTF is uncomfortable to fly with, withthespring centering the throttle stick (Mode1).
RE: Setup Blade mQX to Spektrum DX6i Transmitter
The setup of my Spektrum DX6i to the Blade mQX went without a glitch when I followed the the ‘General Binding Procedure’ on page 6 of the Blade mQX Manual. The Quadcopter was setup 100% perfect without any trimming required.A real magic little Quadcopter this is.
The setup of my Spektrum DX6i to my Blade mQX went without a glitch when I followed the ‘General Binding Procedure’, on page 6, of the Blade mQX Manual.
The Quadcopter was setup 100% perfect to my DXi6 Tx, without any trimming required.
Did you input anything unusual to get it to fly better than with the stock controller? I don't have one yet, but will be heading to my local hobby shop when they get them in. Is it bound as a plane or a heli?
I selected a new model and named it in ACRO mode with all the servos set to normal(none reversed) and sub trims set to zero andturned thenturned theTx off.
I then Installed the battery in the mQX, turned on the Tx simultaneously with the bind button and waited 5 to 10 seconds until the Rx went from flashing to solid blue and that was it.
No further inputis required whatsoever.
