The bare hull is at fightercatracing.com you have to sign up (its free and takes 2 minutes) to see all the items. Ben is great guy to deal with and everything you need can be purchased there. Also building logs can be found on his forum. Its different then setting up a car/truck. If the hardware is pre-mounted, stuffing tube laid inand motor mount installed it's not bad at all. If it's a bare hull its more time consuming then setting up a car/truck imho.
heres the bare hull
http://fightercatracing.com/index.ph...t&Itemid=1
heres the cf hull
thats the same hull as the Genesis you listed from HK. You can see those to hulls under my login, but you may not be able to navigate the site without a actual login.
motor:
http://www.offshoreelectrics.com/pro...82&cat=148
esc:
http://www.offshoreelectrics.com/pro...er-seaking-180
Depending on if you go the bare hull route or the genesis modded route will determine what all you will need. The motor escs will work with any of them. There is also the motor/esc combo package which is a good deal
http://www.offshoreelectrics.com/pro...ose-4082-combo
ORIGINAL: PortoRocSC10
Could you give me links to the setup that you just mentioned (hull,electronics, etc.) so Icould price out the project. Is it hard to put together. IMO it doesn't look at hard as Car/Truck. I could be wrong though. Thanks for the help.</p>
