RCU Forums - View Single Post - Test Stand
Thread: Test Stand
Old 03-30-2012 | 08:28 AM
  #36
wcmorrison
Default RE: Test Stand
Just a word of caution.  The B&D work bench is kinda light.  Be sure to put a big cinder block or even a bucket of water on the bottom step to make sure you have enough blast to take the engine thrust.  BTW that is what I use too.  My breakin stand is simple, Ihave a trainer type engine mount bolted on to a 2/4 inch piece of plywood.  I have a another piece "teed" into that piece and use it for mount tanks.  I then use an old control rod as a throttle link.  It is simple but it works and it certainly is not a pretty as the above equipment.  But then it cost me about $5 in materials and used glue that I use on the models to put it together.  Oh yeah, I gave it a good coat of polyurethan varnish to protect it from the hot glow fuel.
Chip
