RE: Stinger 2
Well, got the engine mount cut. Worked out not too bad. Now just wondering about the throttle linkage. If I mount the engine inverted I shouldn't have too much trouble. With a side mount it seems a little more tricky. AKitoi how did you mount your engine and which way did you rotate the carb? Is the high speed needle up or down? I need to make sure I have enough room for the glow igniter if I do an inverted mount.
Rob<br type="_moz" />
