Rcs
Redrata :
The RCS 140 (moki) is a very good running engine.
Regardless of which one you buy, they will all need to be run pretty much the same way.
When you decide to get one, and need help, just post your question. You will get all the help you need.
They will come with the ignition module. You will have to supply a switch and ignition battery (seperate from your receiver battery.).
