RCU Forums - View Single Post - SE5a 1/5 Scale, can it compete?
Old 04-02-2012 | 04:18 PM
  #64
abufletcher's Avatar
abufletcher
Default RE: SE5a 1/5 Scale, can it compete?
My engine is mounted upright, the airflow works essentially the same as in the diagram below. The blue line represents a balsa baffle that directs the hot air down and out (though a scale opening on the bottom). Note that the fuel tank has been moved up. The opening should be level with the carb.
File Type: jpg
