RE: Info from Data Terminal after a shutdown
OK. In the process of carefully pulling the fuel intake line off the pump I noticed through the plastic covering on the pump that the positive power lead looked very lose. Pulled it carefully and sure enough its come away. Looks like soldering was bad. Am I OK to remove the covering and resolder without invalidating warranty? I'll just try to remove some of it not the whole lot.
