RCU Forums - View Single Post - The Usual Cooling Issue
Old 04-09-2012 | 07:45 AM
Aluminum Overcast
Default RE: The Usual Cooling Issue
For efficient cooling you must have air coming in but you must also provide a way for it to exit too. Where can the air exhaust from? Usually the exiting air from the cowl needs aprox 3 times the area of the inlet to flow efficiently. Can the air exit around the cowl along the gill flaps on your model?
