RE: The Usual Cooling Issue
I may have to try cutting out the chin intakes and making them functional. One problem with trying to come in the top is the needle valve and extension run right through the middle top. So working around that is tricky. The bottom is wide open. I just had my doubts about forcing the air up and then having it find its way back out the bottom again. I really liked the idea of using foam to form the intake and glassing it.
