ORIGINAL: jscraper
to use that clutch bell do i need to change anything else? like the pilot shaft, bearings, clutches, flywheel?
I actually don't remember if you need to change anything or not. I was using both the RS4 and LST bells on my Kyosho Inferno GT I don't remember if spacing was different or not. They should be pretty close though, shims may be all you need I do remember needing 3 5x10 bearings with the LST bell. And if you need any extra length this should get you there
http://www3.towerhobbies.com/cgi-bin...?&I=LXNT03&P=M
