RCU Forums - View Single Post - Spitfire motor mount
Old 04-13-2012 | 07:14 PM
chuckk2
Default RE: Spitfire motor mount
There are always alternatives!
The Eflite 60 should work quite well with either metal post or sleeve mounts, and you can always make plywood box mounts.
The key is to measure the exact distances involved, and determine the motor centerline so that the prop is centered in the Cowl opening.
Great Planes (and others) also make adjustable electric motor mounts.
