RCU Forums - View Single Post - Expo Vs Dual rates
Old 04-19-2002 | 06:35 PM
Goldwing-RCU
Default What?
What do you mean: "Keep in mind that once you activate expo, it is also switched on the respective dual rate switch." ???? So dual rates wont work any more but the Expo will be turned on & off with the same switch?
Mine is a Futaba so I go Negative? Do I set the Dual rate componet up to 100% so they dont do anything, or wont that matter?
thanks
PS is there a BIG difference between 10% & 30%
