Expo Vs Dual rates
you want to go negative on the futaba. He means the hi rate and low rate each can have there own expo setting. you may want -20 on low rate elevator and -50 on high rate as an example. IMO use -20% and keep practicing flipping the rate switches. Expo does not replace dual rates, It mearly softens the amount of throw at the center area
