RE: Anylink problem with 9C
The 9C can pose a difficulty. Don't use the on/off switch of the transmitter. With the 9C transmitter turned on, unplug the AnyLink cable from the module, itself; hold the stick like you normally would, and then plug the cord back into the module. It should now configure normally.
