RCU Forums - View Single Post - Best Kit for First Build
Old 04-18-2012 | 04:50 AM
  #65
acdii
Default RE: Best Kit for First Build
I have a build thread under kit building detailing the plane. Look for Kadet LT52 mod.   I have some pics of the mods I did. <div>
</div><div>You need to use a pushrod for the tail wheel since the rudder is above the elevator, so tying the tail wheel to the rudder would be difficult.  I had a tail wheel from a TF P-51 that I wasn't using and it has the link inside the fuse. It was a little tricky to get it installed, but it worked. Actually worked better than I had thought it would, the plane ground steers much easier than either of my tri gear planes. </div>
