RE: SE5a 1/5 Scale, can it compete?
Don't bevel the aileron. The LE should be rounded and the TE of the wing. If you look close to your photo you will see that there is a flange on the upper and lower surface of the wing TE that bridges the gap.
The ailerons aren't all that wide so two hinges per should be fine.
