RCU Forums - View Single Post - panel lines on Sabre plug with chartpak tape - HELP
Old 04-20-2002 | 02:09 PM
sblack
Default panel lines on Sabre plug with chartpak tape - HELP
Thanks guys,
I figured that if I made the lines in the primer they would get filled in by the tape. Hmmm, perhaps I should have done more testing.
It is a 2 part paint 747drvr, and I had to put that much on because the black wouldn't cover. It will get done - don't worry!
The model is designed for a 3" fan (electric) and is 330 sq in.
I will let it cure some more, then try carefully sanding the tops of the tape. But I will be doing touchups whether I like it or not. Live and learn.
I think I will have to do a bunch of experimenting. I want to figure this out once and for all and see how different the lines look when done on the primer.
Thanks for the advice all
sb
