RE: Well used Yellow F-4 rebuild/coversion to EDF
Ok here is where I need some help, I located the CNC conversion parts for my Dynamax fan. Here is where I need help, the motor they recommend is a HET 700-98 but it comes with several KV ratings. For my application should I go with a higher KV rating? The motor is very reasonable at 69.99 im sure its not the high end but if it will give me reasonable speed im fine with it. Also what AMP ESC and battery whould you recommend for this combo? Thanks in advance!!
