RE: CONFUSED????
I am sorry you continue to have a problem with another member.
If you will check your ratings, you will see the rating the seller posted to your account has been removed. In fact, it was removed two days ago, April 23. The only rating which remains is the one you posted to his account, and the rebuttal he posted to it. Neither of these are reflected in your account however.
The complaint you filed against the seller remains open and will stay in that state until the seller resolves the issue. So long as the complaint is open, there is a warning noted in every ad posted by the seller stating an unresolved complaint has been filed against them. This in itself is a warning to others that they may want to reconsider doing business with that seller.
If you check your account, you will also see the complaint the seller filed against you has in fact been closed. Again, there are NO bad marks anywhere on your account.
I am afraid I do not see how you are being treated unfairly by this site or its staff. The rating posted against you has been removed.
The only time we permit specific people being called out in the forums is if the person has been added to our scammers list. This seller has not been, and for the time being, will not be, added to that list. This situation is still considered as being unresolved and both you and he need to continue to try to work with each other to find a solution.
