RCU Forums - View Single Post - Sukhoi SU-26 MX build
Old 04-26-2012 | 07:41 AM
  #925
Jim Clausen's Avatar
Jim Clausen
Default RE: Sukhoi SU-26 MX build
Raydar,
In my case I set the engine back into the fuselage so that the engine hub was as shown in the plans and made sure that the right thrust was as called for. I also have three servos mounted into the fuselage near the tail. I then moved the battery around and found the C.G. without adding any weight. They do not like to land easily being nose heavy.
Jim
