RCU Forums - View Single Post - Sterling 48
Thread: Sterling 48
Old 04-27-2012 | 06:48 PM
  #46
All Day Dan's Avatar
All Day Dan
Default RE: Sterling 48
Progress has been made. Screw hooks were modified and installed in the hard points under the deck I previously glued in. I traced one of the cabin sides on to a long piece of paper and had Kinko's scan it in to a TIFF data base. I brought this in to AutoCad and designed my own. It was cut from 3/32 plywood and fit in the hull very well. Some 1/4 inch spruce was added to support the center deck and cabin cross pieces because none of the tabs and notches lined up. I sanded off all the tabs and then some to get a good dry fit. As soon as I am satisfied with the fit, I'll epoxy the center pieces in with the assembly on the hull to make sure that nothing shifts around. It's beginning to look like a Corvette.
ID:	1755768   Click image for larger version
ID:	1755769   Click image for larger version
ID:	1755770   Click image for larger version
ID:	1755771   Click image for larger version
