RCU Forums - View Single Post - Small tuning issue
Old 04-28-2012 | 07:54 PM
Gray Beard
My Feedback: (-1)
Default RE: Small tuning issue
If it idles well with the glow driver on then dies when you remove it the problem will usually be just as John pointed out, a bad glow plug. Until that is replaced you can adjust all the needles you have on the engine and it won't idle. What you described is a plug on it's way out, gasping for breath!
