RE: Sterling 48
The rear cockpit deck was epoxied to the rear cabin cross piece with the side inner walls as a support. The instructions had the walls bonded to the hull and the deck was loose. I wanted the deck to be removeable with the cabin. Once again, this was all done with the cabin on the hull to make sure there was a good fit from the cabin to the hull. The rear cabin door was left ajar for a some added realism. Dan.
