Is the thrust 39 or 40.5?
I would definitely rate this engine @ 41lbs,Remember I was only getting 122k Rpm @ 39lbs could be my battery running low causing my engine not to get a full 123K, But if you check another manufacturer 180 class turbine the Rpm is 124 to 125 to get 40lbs.
My Opinion
Here it comes
